I would start with the recommended pressures then go from there. As a rule of thumb, I bump them about 5-10 psi to increase sidewall stiffness and to compensate for temperature fluctuation.
i also run higher than stock pressure in my snows normally around 42 in the front and rear sometimes lower the rear a few psi but haven't noticed a difference really.
