Thought I would give you guys a heads up. Took my car to apply Ceramic Pro, the car came out very nice, however by the rear wing we noticed a couple of dents and we couldn't figure out how it happened. We took it to a Dent Doctor and they were not able to get the dent out as it would always go right back, effectively it didn't react like sheet metal or aluminium would, after sometime we figured out that the material is not metal or aluminium, it is actually some sort of plastic and when they applied the UV light it warped.
Now the whole part has to be replaced which we already ordered. I hope you guys don't face the same issue, make sure to inform them its plastic before applying the ceramic coating to reduce the UV light to minimum.
