[VENDOR][FS]: NEW ADD W1 Version 3.3 Baffled Dual Inlet Oil Catch Can - K8 Stinger Store
Is proud to present to the Stinger community:
The ADD W1 Version 3.3 Baffled - Dual Inlet Oil Catch Can
(BUY NOW)
Description:
The first 2-in-1 baffled OCC with "Triple Twist" technology is now available! No need to run two different cans, the new ADD W1 V3.3 Baffled OCC's 3 port design (2 inlet ports) allows users to hook into both PCV and intake ports with just ONE can! This design is custom made specifically for the Kia Optima & Hyundai Sonata, but can be used on other vehicles as well!
Oil Catch can's catch the oil and moisture in the blow-by gas that causes carbon and sludge build-up in the intake system and engine. It's advanced design assures the best performance and keeps the engine clean even under hard driving conditions.
These ADD W1 V3.3 Catch Can's come with a beautiful exterior redesign over the previous V2 model, sporting a gloss black finish with customizable colored ring inserts. The new design comes with a twister baffled filter which provides the best in oil and moisture filtration by keeping the air longer! This ensures all the oil drops to the bottom of the can. The newly developed twister baffled filter is one of a kind and the only air filtration system on the market!
Easy to service. Highly recommended for tuned vehicles!
Features and Specifications:
ADD W1 V3.3 special engineered OCC
2-in-1 OCC w/ 3 port, 2 inlet system
Eliminates the need to run 2 separate catch cans
Revolutionary designed internal baffle "Triple Twister" chamber filter system
Closed loop system internal baffled Twister chamber filter Catch
Made from Lightweight 6061 Aircraft Aluminum
Fully customizable color insert rings available 8 different colors
Prolong and protect the life of your engine
Baffled interior for the best collection of oil
Available in
Red Black Blue Silver Gunmetal Purple Gold Green
Limited Lifetime warranty
Package Includes:
1x V3.3 Baffled Oil Catch Can
2x 9mm fitting
2x 15mm fitting
1x 15mm hose
Optima Specific Mounting Bracket & Screws
Internal baffle "TRIPLE Twister" chamber filter catch
Vehicle Applications:
All vehicles
THANK YOU FOR LOOKING!
(BUY NOW)
Description:
Available in
Package Includes:
2x 9mm fitting
2x 15mm fitting
1x 15mm hose
All vehicles
[MENTION=77]Paul@K8StingerStore[/MENTION], quick question for you. If this one OCC does the work of two, then what happens with the 2nd open port on the engine? Meaning, it's got the TWO inlets coming from the engine but only has ONE outlet port going back to the engine. That's going to leave either the manifold or the turbo inlets open, isn't it???
Paul@K8StingerStore
There is a provided cap with the kit to plug the open port
