The manual says every 60k miles or 6 years ... "Inspect for excessive valve noise and/or engine vibration and adjust if necessary. Have an authorised Kia dealer perform the operation."
Posts on a Hyundai forum suggest that their 3.3L engine has the camshaft driving solid buckets, rather than having self-adjusting hydraulic lifters (as in every other car I have driven).
Would I be correct in assuming it's the same in the Stinger?
If so, I'm a little surprised by that ... I thought that solid valve buckets were for high-revving hot rod engines, not a general purpose GT.
Just checking them properly (not just listening) requires "removing the engine cover, the engine side cover, the air cleaner assembly, the surge tank, the cylinder head cover, and sliding a feeler gauge between the valve & seat 24 times."
If the clearances are out, this looks like a major operation, because you'd have to take off the covers, camshafts, and install the correct sized buckets (a bunch of different sizes are available).
I would say this is a good reason to be super-strict about changing the oil as recommended.
On the other hand, being a solid valve train, why would things drift out of adjustment, unless the valves are getting hammered into the head and you lose clearance, or there has been oil starvation?
Is this something I should stop worrying about?
http://www.gencoupe.com/general-discussion/452025-cost-checking-valve-clearance-60k-miles.html
