- 726
- 76
- MI
Another tune is about to his the market for the Australian market, currently being developed as we speak.
Installation looks most easiest from what currently on the market.
https://www.youtube.com/watch?v=_iY72F5Nbg4&feature=youtu.be
Key Points:
Key Points:
- Increase boost pressure from 12psi to 16psi.
- Multi Maps (Up to 5 Maps)
- Easily plugs into the stock ECU & ECU harned in minutes, no programming necessary.
- Realizes the full potential of Aftermarket add-on's like Cold Air Intake & Exhaust Systems, as each kit comes pre-mapped for the exact set up of each car or truck.
- No end user tuning necessary, just plug the kit into the car & you're ready to go.
- Easily upgradeable for future add-on's.
- Each kit comes with two maps: a low octane performance map & a high octane performance map, switchable from within the vehicle.
- Fully tunable by a Unichip Custom Tuner for the customized add-on's. THis basically means that the Engine Management System in your ride is now as a tuner friendly as the most advanced Standalone systems in the world, without sacrificing and of the factory features. This feature is unmatched by any reflash-tuning or other similar product.
- Plug 'n Play harnesses are fully Flux capable - purchase the Plug 'n Play kit or upgrade later - Flux simply plugs into the Unichip Plug 'n Play harness.
- Plug 'n Play kits are removed from the vehicle in minutes, returning the stock tuning, without leaving a footprint of ever haveing been modified (a feature which reflash-tuning cannot match).
