Tire Pressure Recommendation with Eibach Lowering Springs
Does anyone know if there is a recommended tire pressure we should be running for the 19" Michelins with the Eibach lowering springs? Just want to make sure that I am doing everything I can to avoid unnecessary tread wear. Thanks guys!! fullsizeoutput_10aa.jpg
Tire pressure is independent of ride height. Follow the manufacturer recommendation and you will be ok. [like]
As long as your alignment is within spec you should not have problems with tire wear.
Also maintain the recommended tire pressure to maximize tread life.
TN
What psi are you guys keeping your tires inflated to?
35psi here
Inside Driver's side door jam
