Not sure if I can post pictures or not since I have so few posts but here is a
link to all my pics of the install.
https://www.flickr.com/photos/billjohnn/albums/72157695223651681
Here's dimensions of the board I mounted the amp to. Disregard the note that the amp can overhang 1-1/4" at the top. I needed to mount it as low on the board as possible to clear the spare tire.
Pulling the signal from the factory amp to feed the LC2i. I initially used the auto turn on feature of the LC2i instead of a remote wire but it wouldn't turn off. So next I used an accessory power wure (blue with red stripe) from the blue stereo connector. Now I am feeding the remote line from the front drivers side fuse box with an inline switch so I can turn the amp off if I remove the speakers.
Power wire and fuse mount. There is a riser available on the left side of the battery to mount the fuse block. I just used self tapping screws.
Finished install. I used self tappers to mount the board for the amp. I used three M6 studs that were already there to mount the LC2i.
Typically I would carpet the boards and make things look pretty but, really why? it's all hidden. I figure it's functional
