Side view mirror assembly removal
Hey guys - tried posting within a few threads but no response. Wondering if may be this helps get some attention as a new thread. I’m looking to remove the side mirror assembly...not the glass, not the cap...the whole thing. Do I go in from the outside or through the door panel? Any advice is appreciated.
Thanks
Right where the mirror is connected on the inside of the door there's a black panel, pop that panel off an there's a couple of nuts holding the mirror on plus the wiring plug. Here's a picture of what I'm talking about, both sides...
D
No dice. Thanks for the reply but that is a solid piece/part of the window surround
D
Looks like there might be a top cover on the mirror mount (outside) or its through the door panel. Guess I’ll pull the panel tomorrow and post an update
My bad, I do believe your right. You need to pull the door panel but it comes off pretty easy... For some reason I was thinking of my Nissan mirror mount..
D
Ok everyone - not through the door panel. Actually even more simple...there is a cap on the bottom of the mirror arm where it meets the body. Use a plastic pry tool and it pops down/off. Inside there are the two main bolts. Towards the front of the car there is a little alignment peg BUT in the middle of the two bolts there is a metal alignment rod/peg. The trick here is that there is a plastic cap with two wings that lock it in. Seems to act as a fail safe so the mirror doesn’t fall out? I was able to reach in with needle nose pliers and peel back (break off...) the wings. Then it’s a jiggle and a lift and it slides right out. One simple connection to unplug and you’re good to go.
Let me know if anyone has any questions
That is good to know, I've never known a mirror to come off that way, thanks for the info..(y)
