Hopefully this is useful for people here.
Those that have the OE battery can check the sight glass on the battery. If it's not green, then it's not operating at full potential. Battery power can affect power to critical components like the ECU, fuel pumps, and not so critical components as the accessories. Those that don't have a sight glass on their battery can use a multimeter to check battery voltage. An ideal healthy wet cell battery will be at 12.7+ volts at rest. 12.4 is required to start the car. The are other tools available to test battery load, but this is just to go over simple maintenance to extend performance and life.
The OE wet lead acid battery is not "maintenance free" if you want it to last long and provide the most power in it's lifespan. Battery acid in each cell naturally evaporates over time and use. So checking and topping off fluid every year is good idea, 2yrs at the most. If you don't do anything to maintain the battery during ownership it will probably last ~5yrs. average, which is about right at the rate at which the acid evaporates and the lead plates build sulfate on them. A slow and uneccessary death.
Warning: Don't do any of the following if you are not comfortable, find someone who is qualified instead. Battery sulfuric acid will eat through your clothes and dangerous to your eyes if it comes into contact.
To maintain the battery pop off the battery caps, make sure none of the lead plates are exposed above the acid level and top off the sulfuric battery acid with distilled water for each individual cell, keeping the level ~3/4" below the filler holes. Exposed lead plates is cancerous to the battery. After topping off the battery put it on a slow trickle charge at 4 amps or less and top off the charge. If you had a battery that didn't show green through the sight glass before, you may be rewarded with it turning green after simple maintenance.
The Magic Eye that is used in Motorcraft batteries provides 4 stages of indication, they are:
1. Green: battery is charged and the acid level is good.
2. Yellow: Battery is partially dis-charged and the acid level is good. Re-charge the battery.
3. Red: Battery is dis-charged and the acid level is good. Charge the battery.
4. Clear and bright: Acid level is low. Add distilled water if possible. Do not fast charge or jump start the battery.
You can see the mfg. date is stamped on the battery in the 2nd photo. After ~3yrs. of use without maintaining it, it took in ~1 quart of water with the sight glass showing black or clear with one cell barely exposing lead plates. After maintaining it I've extended it's life, increased it's performance and got a green indicator through the sight glass.
Clean off any corrosion on the battery terminals and apply some dielectric or lithium grease on the terminals and battery posts.
