- 726
- 76
- MI
Just came across a post on FB where a member in Australia swapped out the front KIA emblems for the E badge as well as swapped out the rear for the larger Stinger badge. The only issue he had was that the outline of the old emblem was still visible. I believe you can easily remove that with a bit of wet sanding.
Note: You have to trim down one of the pins in order to make them fit as the backs are different.
Part# 86330 J5100, 86330J5100, 86330-J5100
Dominic Rob?rt said:
Getting close now .... the dealer has fitted the "E" badges, and the new wheel caps.
Only issue is that the Kia badge on the front has left a faint outline of where it used to be, the E badge is smaller. The dealer says it won't polish out. I can't understand how that can be .... will go check it out before they prep the car.
Anyways .... loving the big Stinger emblem on the boot.
Not long now
Not long now
