How to remove front seat?
Stinger GT AWD
Dropped something and it fell into the driver's front seat track. It's just the front two and rear two track bolts, right?
I don't need to pull the whole seat out of the car, just high enough to get access and remove the item from the track.
Don't think I have to touch the wiring or unplug anything.
Thanks
Yes, there are just 4 bolts, just take the rear 2 bolts out and loosen the front 2 an push the seat up from the back...(y)
KIA-StingerGT
Stinger GT AWD
Thanks!
After some time peering under the driver's seat with a Maglite, I saw the item wedged between the right seat track and the carpet. Using the end of a straightened out wire coat hangar, I was able to finally fish it out.
Dang, that was a tight spot.:oops:
Thanks!
Been there. I dropped a water bottle cap down there. The thin style cap. I pushed the seat all the forward, I pushed it all the way back. Finally squeezed my hand in enough to feel the ridges on the cap and finally moved it out. It also fell in between the rail and the carpet
