- 2,046
- 648
- City
- Houston
- TX
- What I Drive
- Stinger GT2
Rejoice Stinger community, because alas I can confirm that the Wireless Charging feature (originally removed from the US Spec Stinger) is fully compatible with our cars and it is a PLUG AND PLAY afair.
Here is the step by step guide. I did everything from the Passenger side as it allowed me to have more room and not have to deal with the steering wheel.
These are the tools you need to perform the installation.
1x Ratchet
1x 10mm Socket
1x Rachet extension
1x Plastic panel remover tool (I used two just in case I need more prying power)
1x Phillips Screw driver
1x Flat head Screw driver
The first thing you need to do is remove the center console. This will be a great opportunity to swap over to the KDM version.
I did for this installation
Follow the steps given by Stinger GT and Me's video (Link below)
[video=youtube;eTczElThfzc]https://www.youtube.com/watch?v=eTczElThfzc[/video]
Once you have removed the center console. You can now proceed with the removal of the shifter (I have a GT2 so this is for the Stinger equipped with the shift by wire option models with out the shift by wire will differ)
There are four (6) screws that need to be undone in order to remove the shifter.
These are three phillips
And three 10mm socket
Once the screws are undone you can now move the shifter freely. Go ahead and unplug it from the harness.
With the shifter out of the way you can now proceed to unscrew the two (2) screws holding down the trim around the climate control.
Once the screws are removed, you can now proceed with the removal of the beauty panels located on each side of the center console (sorry forgot to take a photo of the drivers side).
These two panels are held by three (3) clips, that can be seen from the inside of the console.
Using your plastic panel remover tool go ahead and pry the panel out, I had to help myself by pressing on the from the inside out. It made it eaiser. Once you get the first clip out the other two come out easy.
NOTE: Be VERY careful when prying the panel out, it is very thin and can bend easy.
Drivers Side
Passenger side
With the beauty panels removed. You can proceed with the removal of the climate control. No tools required for this step, only brute force and caring.
This is the tricky bit of the hole process, as I spent a considerable amount of time testing different amounts of force to remove it and found that it requires a considerable amount to push it out.
The best way I found to remove the climate control panel, without causing any damage to the buttons or knobs was by pressing down right the two knobs are (on the black part not the knob it self)
You need to press down hard on both side at the same time.
NOTE: See position of the climate control panel on the picture for direction reference.
Now that the son of a gun climate control panel is unhooked, go ahead and unplug it from the harness.
Now we move on to the actual removal of the console.
On this step you will removing five (5) screws, all of them 10mm socket
One right next to where shifter is mounted
Two inside the console itself (there is a small carpet you will need to lift in order to access the screws)
Once on the drivers side (behind the beauty panel)
Once on the passenger side (behind the beauty panel)
With the screws undone, you will need to disconect the harness for the rear climate control and 12volt plug and USB from the console
Once the harness is disconnected MOVE the hole console backwards just a little bit, just enough to have enough clearance to remove the glossy trim that goes around the climate control panel.
With the console moved and with enough clearance insert you plastic panel removal tool on the back clip. Remember there is one on each side (passenger and driver)
Passenger
Driver
Now go ahead and remove the panel
Next up is the removal of the tray itself, this is the last step and the easiest one as there are no screws to worry about.
Firstly you will notice that the tray is held down only by clips and a small hook on the rear.
To remove the tray somply place your hand underneath the tray and push UP.
Once the tray pops out go ahead and pull it towards you, but be careful not to pull to much as there is a harness that needs to be unplugged.
Proceed to unplug the two harnesses on the tray.
Now grab your wireless charging tray and plug it in.
Make sure the hooks on the rear of the tray are IN properly
Now press down on the front of the charger until it clips
Looking good so far
Now you can start putting every back together. Basically following the same steps in reverse order.
NOTE: When putting back the console make sure these hooks go back in correctly other wise you will have fitment issues
Another observation worth noting is the beauty panels also have a hook that needs to sit properly
After everything is put back together you will need to turn on you car and navigate on the center screen on your dash to the Settings menu, then scroll down to Convenience and scroll down until you see Wireless Charging. If that option is enabeled Congratulations!! You have succesfully installed your wireless charger.![Big Grin [biggrin] [biggrin]](/images/smilies/biggrin.gif)
![Rock On [rockon] [rockon]](/images/smilies/icon_smile_headbang.gif)
Hope this helps anyone looking to have this amazing feature enabled on their Stinger.
Finished product with the KDM Console
Rob
1x Ratchet
1x 10mm Socket
1x Rachet extension
Drivers Side
Passenger side
Passenger
Driver
Looking good so far
Rob
