Grinding down the pins is the easy part. Is the spacing between the top 2 pins the same as the front hood though? It also comes with adhesive attached, but I wanted to make sure the shape would sit flush without looking weird.
The curvature can be overcome by applying more tape in the middle, but the 3" E emblem is barely wide enough to cover both holes in the rear, the pins are spaced further apart in the back.
With the Stinger Script emblem, the holes are covered up by the
N & G letters.
Rear Stinger Emblem Holes:
I did an overlay so you can see it barely covers the holes.
This is where the holes would be. Make sure you fill in the holes with silicone.
