GDI Pump
Joeeagle
Lutz
22 Stinger GT2
Anyone having issues with the GDI gas pump under your hood ?
Welcome @Joeeagle, yes there has been a few people that have had the low pressure & high pressure pump replaced....
J
Joeeagle
Lutz
22 Stinger GT2
My 22 stinger gt2 GDI pump is very loud when the engine is cold and then gets little quite once the engine reaches temp. Is there a way to have them tested to make sure it's allowing enough gas to the injectors ?
That is normal on cold starts for the high pressure pump to make noise because it's a mechanical pump..
2018 Kia Stinger Limited
If the engine is operating normally, then your pump is operating normally (unless there are significant abnormal sounds)
The pump is not silent
