FM Radio Reception - Comes and Goes?
I don't listen to FM much. But when I do, I've noticed the volume of the station coming and going - whether I switch to HD or not. Anyone else noticing this? Suggestions?
Yes this happens to me, I even brought it up with our salesman during the test drive.
Thank God! I'm not going crazy and I won't feel bad bringing it up to my service writer! LOL
I can confirm this happens to me too. I thought it was a feature on radio that cuts volume whenever it detects poor reception so you don?t get static blasting in your ears.
I would suspect it is a combination of two things. One is that these little "horn" multi-purpose antennas they use on the back of the roof are not optimized for all frequencies since they must deal with Sirius, FM, AM, and satellite data all in one unit.
Second, FM is subject to multipath distortion from reflected signals. If you drive through town with tall buildings or beside a semi truck on the highway, you get reflections that are slightly out of phase with the main signal. Those out-of-phase signals effectively cancel the signal until you are past the reflective surface. Same principle used by noise-cancelling headphones in using out of phase sound.
The radio reception on the Stinger is horrid compared to my STi and Focus ST.
First, depending solely on the "fin" antenna on the roof would be a terrible decision. I'm sure Kia's not done that.
Second, I don't need to go through an stand of forest or skyscraper-laden skyline to have the signal come and go. It can do it going down a flat, field-borderd, deserted two-lane.
Ford F250 7.3 Powerstroke
Stinger antenna
As a matter of fact that is the only antenna. It is powered from the audio unit and it separates out AM/FM, Satellite radio, GPS signal, and Telematics into 4 distinct signals and carries them to the audio unit on separate conductors.
Hapa88
2019 GT1
The shark fin antenna is not the radio (AM/FM) antenna. The radio is on the rear glass.
From the owner's manual.
My 2019 Owner's manual (pg 4-164) states "The shark fin antenna will receive both AM and FM signals and the transmit data." There's no mention of a glass antenna. Must of been a change from 2018s to 2019s..
Anyway, I notice my FM reception going in and out as well, but it appears to be happening when the HD signal is weak and the radio keeps switching between standard FM and HD.
WI
‘19 Stinger GT
2019 here, haven’t seemed to have noticed any issues with FM. It’s not my first audio input choice but when I’ve used it I haven’t experienced those issues.
Thread Starter #13
I'd not listened to the radio in ages and just did for a few hours last week. It does fade out and back in. This is with the latest HU update (Nav, s/w, etc.).
