No, you can turn the A/C off by using the control on the panel. That will take it out of Auto climate mode. It will run in the winter because the A/C helps dehumidify the air for defrosting and defogging when in those modes. The manual also tells you to run the A/C periodically to keep seals lubed if you turn it off frequently. Modern compressors take about 5HP to turn, so it isn't much, and not as much as a strong headwind.
