Cold Start - Engine sputtering/Missing
mfox
2018 Stinger
Is it normal on morning cold starts engine seems to be missing/ sputtering slightly for first minute or so?
Then it seems to level out and is fine.
That's not normal, mine doesn't sputter when its cold.
2018 Stinger GT1 + Drive Wise
Hasn?t happened to me.
I am not diagnosing your problem, only giving my opinion and known knowledge. Take it to the dealership and they'll know what's wrong.
Correct me if I'm wrong but, I believe these are still considered GDi motors. They use a fuel injector that has 6 smalls ports instead of one. These small ports will collect with carbon and produce what you are describing. They clog and take a few seconds to clear out. It is more common in motors that take short trips rather than long hauls. I have the same issue in my 3.8. It's known for these motors to produce high carbon levels and it doesn't help that the injectors have small ports. This is considered "normal" by Hyundai/KIA even though they don't recognize a service interval in the manual. Pretty pathetic since this happens to A LOT of GDi motors. However, yours should not be doing it this early in ownership. How many miles do you have?
I agree with [MENTION=94]Stingin' Away[/MENTION] here assuming it's not a high pressure fuel pump issue. In the manual, it is recommended that you use only "top tier" fuels in the car (because of the additives in their fuel -- see toptiergas.com for a list) and also they recommend using an additive like Chevron Techron which contains a very strong solvent (a polyetheramine) that dissolves carbon deposits every 6,000 miles at oil change intervals.
mfox
mfox
2018 Stinger
Thanks for the advise guys.
Car only has 1200km on it.
Going in to the dealership next week.
SQ22
Fuckoff
2022 Kia Stinger Gt Line
Any updates? Mine doing the same thing
