Bolt behind passengers side air cleaner
2019 Kia Stinger GT1
Does this bolt serve a purpose or was it placed there to torture the minds of the super inquisitive like myself?
AFAIK the bolt serves no purpose, however I would not be surprised if its holding a bracket on the other side.
AR
I've always thought of it as a grounding post for jumpstarting the battery.
mzones
1999 Lexus GS 400
According to the manual, it is indeed the negative connection point for jumping the car. For the positive, you have to remove the plastic cover with the "+" sign about 18" behind the bolt in question. It is unpainted in order to provide a better connection.
hoserama
thanks!
Excellent. Thanks for clearing it up.
I work for Kia and you are correct
edge9421
The positive terminal under the hood is way too far from that bolt for a portable jump starter to reach. I don’t use jumper cables anymore because portable jump starters stow in smaller spaces and are also useful for charging a phone in a pinch. I may need to drill and tap a new location for that bolt.
