Autohold/EPB
Chestnut mound
TN
2019 kia stinger GT S
I own a 2019 GTS RWD that I bought 5 months ago with 5k on it and it runs strong, handles flawlessly and I couldn't be happier however something that has happened several times but not often or consistently is I'll make a turn normally or could just be driving and the Autohold and EPB lights on the dash light up and stay lit until I shut the car off and restart it at that point the lights are still lit until I pull it in gear and take off. I've checked and neither the Autohold or Electronic Parking Brake are engaged when this happens so I'll have it checked out next time I take it to Kia for service. So my question is has anyone else experienced this problem? If so what did you do about it? Thank for you time
I've never had that happen, The next time it happens take some video of it so you have something to show the dealership..
A
Chestnut mound
TN
Already have it but thanks for the suggestion, it doesn't affect anything about the operation of the machine and I'm thinking it may just be a loose ground somewhere, but nowadays with the way cars are built who knows
New Orleans
2018 Kia Stinger Premium
Same issue! '18 Premium with 32k miles. Sometimes when I turn the car on and even in drive ill have the ABS, Auto hold, and TC light on. It started for me a little over a week ago.
A
Chestnut mound
TN
I've resolved the problem when I changed the pads and rotors, because of the e break censor if the rear pads wear down to the indicators the problem can and in my case did happen, if you haven't put brakes on yours it's a safe bet you need to because the OEM rotors and pads are garbage, if you have you might want to check pad wear, hope this helps
New Orleans
Noted, im taking her to the dealer very soon! Thank you!
