- 103
- 35
- Non-US
- What I Drive
- 18 Stinger GT2 AWD
Pretty easy.
Yank - terminal from battery
Use flat blades screwdriver with the flat blade perpendicular to the plane of the steering wheel on the 3 ?push? ports to pop out the airbag module.
Unplug the horn/2 airbag plugs
Unbolt main center bolt (21mm with extension and breaker bar).
Remove wheel.
Work slowly, paying attention to screw locations and cord mapping / paths.
Don?t force anything. If something is stuck, there is a screw.
The tricky part is that you can?t pull the left/right button Banks until you remove the paddles. There are 2 screws at an angle holding those in. Remove those first, then gently rock the paddle shifters out and unplug.
Everything transfers over except the gloss trim at the bottom (but screws are needed).
Pretty simple...
Remove wheel.
Pretty simple...
