Aftermarket swaybar End Links
Does anyone know of any company out their that make aftermarket Swaybar End Links for the Stinger. The stock links that come on the car are weak and have flex in them. If you replace your Swaybars with a larger diameter ones you should replace your End Links.
I cant seem to find any!!!!!!!!!!
Haven't seen any end links, there is a swaybar available from Eibach
There was a prototype a Korean company was working on for the Stinger. Have yet to see any updates.
Sounds good, thanks for the info. If you could remember the name of that Korean company that would be great. I would appreciate it!!!!!!!!!!!!!!
Thanks [MENTION=187]winningGT[/MENTION] for the info....
Got the Whiteline endlinks installed, those stock endlinks are garbage. WEAK [wrenchin]
I’ve been eyeballing those along with the stainless braided brake lines. Any discernible difference?
Thread Starter #11
The stock endlinks on the car have a lot of flex and the ball joint is plastic. You would notice more of a difference when you change the sway bars out. With the sway bars an endlinks changed out it will make the setup more rigid.
