Aftermarket shift paddle extensions
tcam33
Kia, Subie, KTM 1290
Where did you find them with out the branding? These look much better that the branded ones.
18 Stinger GT2 RWD White
OK, so if anyone is looking for these K8 Stinger store https://www.k8stingerstore.com/products/aluminum-paddle-shifters?variant=12217423167584 has these for $79.96 and Import Shark http://importshark.com/catalog/prod.../2415/osCsid/a33328db898ade745c5692b8389036a3 has them for $155.00. Needless to say I'm not shopping Importshark!
UPDATE.... I got them from K8 Stinger Store. They look good but they don't function as they should. The pressure applied to the top of the extended paddle twists the factory lever resulting in nothing happening. You might get about a finger width above the factory where they function as advertised, but the other four inches are unuseable. They look great, just don't perform! I'd say a waste of money.
SaleenTom
Installed mine and they do look amazing. As stated above there is not enough rigidity near the tops.
They do widen the stock profile so that they feel more to the sides, however. 80.00 was worth it for me.
That looks great, where did you order them from?
So anyone have a fix for this issue? I know other car brands have huge levers and they don't seem to have issues like we're experiencing....
I think the problem is that these extensions are held on by for tiny screws, which doesn't provide sufficient bracing. I bet if some one use an epoxy glue instead it'll be a lot of more rigid.
A set of paddles on ebay is only $45.
