- 36
- 9
- TX
- What I Drive
- 2013 Focus ST(Stinger GT1 soon)
Okay, So after quite a bit of reading up on wheels and tires that have been tested to fit the Stinger, I have been wondering if 295/30's could fit. The benefit being they are the same height as stock 255/35r19's (only 0.23% difference), and this allows you to run the wider 255/35r19 front and have the same height tire in the rear rather than running the shorter 285/30's.
I read that 19x10 et40 and et55 running a 275/30r19 are the limits in both fender clearance and suspension clearance. Assuming that the tire used is a Michelin PS4S, choosen because it is a popular tire and is known to run wide as well as it being available for both front and rear sizes mentioned, the following info was calculated:
- 19x10 et40 with 275/30r19 PS4S:
- 19x10 et55 with 275/30r19 PS4S:
Limits:
Okay, So now that the limits have been determined given those wheel setups, we can move forward to figuring out if 295/30's can fit properly without issue. From the info I have gathered on the 10in wheels mentioned prior and getyourwheels.com suggesting to get 10.5et45 for the rears and running 285/30's, this is another point to figure out what fits. Technically getyourwheels.com suggested 20's, but the math will still be fairly similar to 19's as the tires are the same width and they wouldn't recommend something that would cause rubbing hopefully.
- 19x10.5 et45 with 285/30r19 PSS(no PS4S in this size, but still a tire known to run wide):
Given the offsets for the 10in wheels, 40mm and 55mm, we can adjust the offset range to a 10.5in wheel pretty easily. To make this faster than writing out all of the math you can check on willtheyfit.com to see that the offsets match to the side of the wheel they need to.
- 10.5in wheel offset range: 46mm to 49mm.
So with all of this said, sorry for the massive wall of text and numbers, but I want to make sure I am very thorough with the calculations so it doesn't seem I pulled them out of my ass.
- 19x10.5 et47 with a 295/30r19 PS4S: <---The calculation you have been waiting for.
- Tire measurements were done on a 9.5in wheel, so assuming when it is mounted on a 10in wheel, it widens by 0.5in would be a safe bet.
- The measured section width of the tire on a 9.5in wheel is 10.9in, so that would make it a 11.4in wide tire(289.56mm)
- 289.56mm / 2 = 144.78mm which gives us the distance to the edge of the tires assuming we are measuring from the exact center.
- 144.78mm - 40mm = 104.78mm, this is the distance from the wheel mounting surface to the outside edge of the tire, which is the limit due to the fender.
- Assuming the same tire math from before the only difference now is the offset and the fact we are measuring to the inside of the tire instead.
- 144.78mm + 55mm = 199.78mm, which is the distance to the inside edge of the tire, making this the limit due to the suspension.
Limits:
- Fender: 104.78mm outward from the wheel mounting surface.
- Suspension: 199.78mm inward from the wheel mounting surface.
- Tire is measured on a 10in wheel, so assuming once again that it widens by 0.5in when mounted on a 10.5in wheel, it is a safe bet.
- The tire is 11.4in on a 10in wheel, making it 11.9in(302.26mm) on a 10.5in wheel.
- 302.26mm / 2 = 151.13mm.
- To the outside it would be: 151.13mm - 45mm = 106.13mm
- To the inside it would be: 151.13mm + 45mm = 196.13mm
- Seeing this means either these will poke out more or we actually have more space outward than previously calculated/tested. So for now lets assume the prior numbers from the 10in are the actual limits just to be safer.
- This shows the getyourwheels.com recommended size is actually outside the range, but we can adjust the range to include it if desired, or ignore it because of the following.
- The midpoint between the two offsets, which would allow for the widest setup possible, is 47.5mm, if we err on the side of caution so as to not be rubbing 100% of the time on the suspension, it is best to set it to round down to 47mm as it will push the wheel out by 0.5mm.
- Also notice that if we had included the 45mm offset that was recommended, the midpoint would also be 47mm so excluding/including it wouldn't really have any effect.
- The tire was measured on a 10.5in wheel, so the given measurements are perfect as is, which is nice.
- Section width is 11.9in(302.26mm)
- 302.26mm / 2 = 196.13mm
- To the outside it would be: 151.13mm - 47mm = 103.13mm
- To the inside it would be: 151.13mm + 47mm = 198.13mm
