Installed my wheels yesterday and I am very happy with the fitment. I wanted a little meat on my wheels rather than a thin lip so I went with 255's in the front and 295 in the rear. I took several measurements before buying them and decided to go with an aggressive offset in the rear with 295's and thankfully they fit perfectly, the front's I got +42 but they rubbed on the strut, with a 3mm spacer they cleared but it was too close to be safe, so I ended up with a 5mm spacer. My dealer sourced the wheels/tires from "Get Your Wheels", they did a good job and packaging was great, I recommend buying from them.
I also installed the Maxton Design V2 front lip and side skirts.
ACE Alloy - AFF02 Black Chrome
Front - 20x9 +37 - 255/35/20 - Firehawk Indy 500
Rear - 20x10.5 +50 - 295/30/20 - Firehawk Indy 500
Weight with tires,
Front - OEM 24.6kg - ACE 24.5kg
Rear - OEM 25.7kg - ACE 26.6kg
Car is much more stable and handles better with very minor increase in road noise, ride comfort is almost the same as well.
Weight with tires,
